Flowmaster Super 10 Install
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Jet: my past experiences just doing true duals with out adding headers & a tuner might slightly lower your low end torque curve.
Not enough to have any notable difference.
Some might notice / Some might not without a dyno run.
Depending on your future mods / just a simple muffler swap will create impressive results in sound & a tiny feel in performance.
The stock Exhaust system flows quite well.
Like I said: All depends on your future mods!
There are videos on YouTube of true dual systems with different diameter of pipe which causes some eye opening results: example Complete 3" dia Exhaust compared to a 2.5" as well a 2".
As well as muffler design.
My only advice would be go to a straight through muffler design when switching & if going with a true dual system add in a X pipe adapter.
Seth_5.7
Seth_5.7
North Carolina
What is the benefits of an x pipe? As i currently don't have one
Sent from my SM-G920P using Tapatalk
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Basically equalizes the back pressure between both backs.
No real performance gains: Its more about efficiency of the flow. (You might be able to see a fraction more (smoother) power but only through a dyno.)
Plus gives the sound a bit more deeper tone.
https://youtu.be/55Ui2S-i0to
https://youtu.be/Y0Va3sDhqwI
https://youtu.be/Dd43rwLHEW4
I consider Kinney Custom muffler shop one of the best in the country!
They incorporate either a H-Pipe or X-Pipe into every true dual system they create!
https://youtu.be/iRJUgTseT2E
Or a Cross Flow Muffler (Dual in / Dual Out)
https://youtu.be/mrBsaWPrU4Q
