Fluid Changes
adrian_cast
Ontario, Ca
5.9L
Just picked up a 2007 5.9L Ram 2500 Mega Cab. Want to change the rear diff/front diff, engine oil and transfer case. My truck did not come w the owners manual. Can you guys help me out w the factory gear weights, qts, recommendations etc.
Also new to the whole plate style diffs. Had a Tacoma before and it was a drain plug style. Seems a lot easier.
Thanks!
Burla
2010 Hemi Reg Cab 4x4
Read my oil filter thread in my sig, I believe the correct RP filter is part number 40-780 royal purple, double check that here right corner.
Don't use their fluids, use ester based redline for those applications, or at least m1 as they also make some good gear fluids.
Automatic Transmission Mopar ATF+4. This is the proper Redline c+.
Transfer Case Mopar ATF+4, Automatic Transmission Fluid.
Manual Transmission Fluid G-56 Mopar ATF+4, Automatic Transmission Fluid.
Front and Rear Axle Fluid 2500/3500 Models GL-5 SAE 75W-90 Synthetic or equivalent. 2500/3500 axles do not require limited slip additive. This is the right gear fluid.
Check Nick at got exhaust vendor here, he literally has best pricing and shipped to door free. PM with everything you are considering, and he will give you a price, and it will likely be lower then you can get elsewhere. You can use redline engine oil, but I would look at Rotella or Delvac for the diesel. Cheapest place to get delvac is costco, and they run sales on it every other month.
Take the diffs cover off, check for metal, especially with a 2500.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Thanks!
Here is a link to help you decide on engine oil, 219 oils tested and compared against one another. Enjoy!
https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
Burla
I think he did. He linked a downloadable version of the owner's manual for you. Clicky click.
Yeah and I gave him the exact weight and recommendations he asked for, lol. Sorry OP I did my best, maybe someone can do better.
adrian_cast
adrian_cast
Ontario, Ca
5.9L
Oh **** haha. Wasn’t highlighted for me viewing from my phone. New to this forum. Little different from tacomaworld.
