Fluid volumes for diffs, trans & trans case
Bingo
Ottawa, Canada
5.7 Quad Cab Sport
Planning to change the following shortly. But i'm unsure on how much fluid i need for each. Can anyone enlighten me?
1. Rear axle - 75w-140
2. Front axle - 75w-85
3. Transfer case - BW44-44
4. Transmission - Whats recommended to use here too? as well as volume
(i'm waiting on PPE pan too. i read they hold a bit more.)
Interested on brand recommendations too
I also read being as mines a later bw44 best to use dealer fluid for that.
'16 4wd with auto button 5.7 8spd 3.21 NO LSD
Thanks
B
Bingo
Ottawa, Canada
5.7 Quad Cab Sport
So i just came across amsoil site and found the following info
Front axle - 1.1 litre
Rear axle - 2.2 litres
Transfer case - 1.4 litres
Transmission - 8.3 litres
(ppe holds 2 quarts more so an additional 2.2 litres on top of 8.3)
Does this sound about right?
caulk04
Supporting Vendor
Yup, sounds good.
I just did my 8spd trans with a PPE pan last Friday, used a tickle over 7qt.
Be sure to lube the oring on your filter and carefully slide it in. I pinched mine last time...
Burla
2010 Hemi Reg Cab 4x4
For your 8 speed most guys use maxlife or lifeguard, the lifeguard is a clone of Mopar which is $$$ but lifeguard is still $$ as Opposed to maxlife $. The main difference is maxlife is red and the others are green. I have not seen Mopar so cheap as this.
Burla
Looks like the one item where the price has came down from earlier examples = Mopar fluid. Used to be 30 bucks or close now generally looks like 1/2 that.
caulk04
Supporting Vendor
stenerson
New Hampshire, USA
3.6 VVT
I did a drain and fill last weekend and replaced the zf8 tranny with a PPE pan.
I used about 6 quarts of fluid. My pan rail was perfectly level front to back
and just a slight lean towards the driver side. So may have overfilled a couple ounces. I got six quarts left of the Amsoil I'm using so plan to do another drain
and fill soon to get most of the fluid replaced.
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
That Mopar fluid for the BW transfer case is almost 3 qts…and it is NOT CHEAP. PLan on $80/qt or more.
B
Bingo
Ottawa, Canada
5.7 Quad Cab Sport
So i thought was 8.3 litres stock plus 2 extra that ppe pan holds?
Usually you only get at the most maybe 5.5 litres/quarts out of the ZF on a normal pan drop,so 8 litres/quarts is more then enough fluid for the PPE pan
B
Bingo
Ottawa, Canada
5.7 Quad Cab Sport
So any ATF full synthetic for trans?
Also annoying that mine calls for 75w-85 that i can only get online but i can get 75w-90 easily locally and 90 is cheaper by a fair bit.
Nope,there's basically only a couple fluids that have a proven track record in the 8 speed,one is the OEM fluid,the other is Maxlife. Redline and Amsoil don't have the greatest rep in the 8 speed.
I can't speak to the Maxlife,as i've never used it,but it has a good track record from the guys who are using it.
Grams
2024 & 2015
75W85 from Valvoline is found at the Zon and any Walmart very reasonably priced.
75w85 -75w-90 is there that much of a difference?
Not enough to worry about.If all you can find is 75W-90,it'll work just as well as 75W-85
