FOB range SUCKS!
MyOhFive
HEMI
I have the passive entry system, and my auto start range really sucks. Sometimes it won't catch even from ~100ft away. The other night I was in the change room at the gym, and the truck was no more than 100 feet away, but with 2 walls between, and it didn't start.
Is this normal?
The Q
South Texas RGV
2014 Sport R/T
I use to think it was normal, but mine is now starting from greater distances and from within buildings with multiple walls. I think I've just finally learned that the two button pushes need a little time between pushes. I was trying to remote start with two quick pushes of the FOB button. Now I push the FOB button, wait briefly push again and the truck starts.
clh1220
st Louis
You can always just use your phone to start it.
N1ck
Regina Sk
I've got the proximity system and my god is it bad! I have to be in clear view of my truck and 50ft away for it to work!
dkmesa
I tried that earlier this week and 4 minutes after sending request my truck still had not started...
baum
savage, mn
2015 Laramie
this is the downfall to the factory systems. aftermarket ones will easily do 10x the distances. you have to wonder why the factory cant put that technology into theirs.
i use to have a remote start that i could start in a shopping center and i was on the opposite side from my car. the good old days.
ramforme
hemi
You've got my attention!
RAM has an app for android and I assume ios if anyone still uses that antiquated operating system :).
The problem is they only include a few initial months of service then you have to pay an exorbitant monthly amount to continue service after that. I think the majority of people refuse to do this and I do hope it sends a message for them to lower their ongoing service fees. I used the app - their is quite a delay sometimes lasting up to 5 minutes although a few times it was much better - only 2 minutes or so.
VPRPWRD
8.3L Viper
I watched an old episode of top gear and they had a bizarre way to increase your remote range, put the remote against your head and push the button. I didn't believe it until I tried it this morning and unbelievably, it works!!
Reactions: jbr
clh1220
st Louis
It's the uconect app. It is a paid subscription for 15 a month you can lock and unlock and start and turn off with your phone. You get voice texting and yelp with it. I have it just for the texting ,I have too many customers texting me anymore. I know it's not real cheap. But it's worth it to me. The longest I've waited for my truck to start is 3min. You could always start it early. And you get a notice in the phone app that it received the command.And a email. I have a galaxy s5.
ramforme
hemi
My 2013 subscription ran out a long time ago. But I still have the text vocal read. It IS pretty cool to have your texts read out.
KarL45
Western Slope, Colorado
2018 Ram Express quad cab 4x4
5.7 MDS
FOB starting
Hi. Well, guess I should be envied. lol My problem is that the Fob is "too sensitive". I usually carrying a few other items in my jean pockets or lean over something and "****", the truck is started, locked, or unlocked. Wish there was some way to de activate the fob when I don't need it.
PostalTwo
Edmonton
hemi
I don't have a range problem either if I point the remote at the truck I get 300+ ft range
Gill
New Jersey
2014 CC Sport 4x4
I had my first issue with the key FOB range two nights ago. I have always been able to start the truck from quite a distance, distances that surprises me at times, as long as there was a straight line of site between the fob and the truck. However the other night temperatures were in the single digits, like COLD COLD, and I could not get the remote start to work until I was literally one foot from the truck. I actually thought the trucks battery died. The unlock FOB command wasn't even working. It wasn't till I was standing beside the door that the FOBs functions worked. I'm chalking it up to the fridges temps?? I haven't seen an issue since that night with the range, coincidentally temps have increased slightly.
MyOhFive
MyOhFive
HEMI
The ucconnect system they're talking about isn't available in Canada, for no ******* reason whatsoever. Truly pissed about it. So we're stuck with FOBs
I knew someone would mention the holding it under ur chin trick lol and I don't wanna look like an idiot just to start my truck.
ramforme
hemi
Aftermarket transmitter and/or receiver/antennae booster- problem solved! Uh...except no one makes one that I know of.
baum
savage, mn
2015 Laramie
oh yes they do!
you need one of these
http://www.amazon.com/XpressKit-DBALL2-Databus-Bypass-Module/dp/B00H2PHSY2
and either of these (a remote kit, may be able to fid it cheaper and there are a few different choices)
Python 9752PL 2-Way LC3 RF System w ith XL202 (for use with RXT and RSR Interfaces) at Onlinecarstereo.com
or
smart start (dei)
Viper VSM50BT SmartStart Module
in which i believe the smart start works in canada. these modules cal also be programmed to turn on the heated seats/steering wheel, defroster just like a factory remote start.
N1ck
Regina Sk
Well that's a kick in the ass :flipthebird:
ramforme
hemi
oh yes they do!
Amazon.com : XpressKit DBALL2 Databus All Combo Bypass Module : Car Electronics
or
smart start (dei)
Interesting, but none are plug & play type longer range transmitters that can take the place of the key fob transmitter and instantly interact with the existing system and wiring, which is what I would want.
"Requires splicing into vehicle's factory wiring"
joshhhh
