So I ran my truck out of gas. Put about 2 gallons gas in my truck. It started sputtered stalled a couple backfires then stopped and died. Wouldn't start again. Found out someone had added sugar water my gas I don't know how long it it been in there. Drop the tank cleaned it out really good didn't notice any sugar in the fuel pump. Put the tank back on everything else and it sounds like it wants to start but it won't what can I do now?
If sugar water had been put into your tank. It has a long way yo go. The fuel filter was in the tank. It would have been water wet. That needed to be changed.
Second is uncovering the air box and air filter off the top of the engine. Next was checking the Schrader vale by unscrewing the cap and with a rag seeing if you have any pressure at all. If none is evident have a helper jut turn the keep on for 5 seconds at a time without trying to start it. Do that 3-4 times, If no pressure. Your heading back to the pump in the tank by troubleshooting that part of the system. Check fuses and connections as you head back to the tank. If you find the pump is not running you'll know it's either a electrical issue for that pump or the pump itself. Or even that filter in that tank which could be blocked.
Back to first step if you have fuel pressure at the Schrader valve. You have other issues, and more trouble shooting should be done.
You'll find YouTube is a great source on many things by priming the fuel line, testing for pressure, and replacing the complete pump in the tank. Its basic mechanics at this point. Anything beyond this needs a bit more experience and would pay you to have someone with a bit more knowledge to help in person.
Those speaking of putting gas into the throttle body. It would be a mist because pouring gas in is that it ends up at the bottom of the plenum. Not the cylinders. A disposable plastic sprayer should last long enough to work set on wide spray. Probably Trash the sprayer tho.
Using starter fluid directly into the throttle body can blow a head off. Seen a guy do that once. It should only be sprayed out side the air intake before the air filter.
