Frequent stalling starts right up.
RHAmber
2012 1500 5.7, 224k miles; stalls frequently starts right up.
After following several suggestions, fuel pump, coil packs, throughout throttle body, crank shaft angle sensor, map sensor.. the ignition model was the problem.
I opened up the ignition module and the contacts were corroded badly. Used 3000 grit sandpaper from headlight polish kit. Problem solved - finally
