Front axle shafts
chrism1367
So I think my passenger (and maybe driver) side front cv axle is going bad on my 2013 ram 1500 4wd quad cab. Seems that both front ahafts are exactly the same part. Ive never replaced one and am looking for aome experience with this. I hear a metal clicking sometimes and also a dull hum, more so when turning right. I checked I joints and all seem solid with no play. The front shafts have some play and looks like one joint pass side has quite a bit of all around play in it. Anyone ever replace these? How hard is it? I scheduled an appt for this wed to have a garage take a look.
misfit77
Glad you wrote this
I am getting a rumble too on my 2014. 89k miles. Sounds like a knobby tire but my all terrains aren't that aggressive. Only when turning right, sometimes when slowing down.
I hate arguing with dealer so I hope it gets worse before my warranty is up
Sent from my moto g(6) using Tapatalk
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Check the wheel hub. That's exactly the noise mine made before I replaced it.
C
chrism1367
I may replace the wheel hib also, but there is definite looseness in the cv shaft. I grabbed it and it made metal sounding noise, similar to what I hear sometimes when driving.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
If you end up needing a wheel hub assembly they are priced all over the place from as little as $70 a hub all the way up to $220 a hub. I saw zero advantage from one to the next. I'm familiar with timken since they provide OEM parts to the manufacturer.
C
chrism1367
rockauto seems to be a good place, going with timken as well. Although noone chiming in with experience in replacing shafts?
RedSRT4Me
Scottsdale, Az
2015 CC Sport
The the reason your axle is loose is because it is splined into the the hub assembly. If the hub is moving it will cause the axle to move. ;)
C
chrism1367
Hmm good point. I did have both wheels of the ground and dudnt seem to notice any play. I may have to check again
FF1899
Syracuse NY
A bad bearing isn't always going to have play. Lift it in the air hold the spring and spin the tire if it feels smooth and there is no play chances are the bearing is fine. If it's bad you will feel the roughness while you spin it
renfrick1
New Fairfield
I did both of mine. It’s not hard if you have the right tools. YouTube is your friend. Watch as many as you can. I did shafts hubs rotors and pads for less then $500 I think. It took 2 days. First side took all day because I never did it before. The other side took about 2-3 hrs.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Same boat as you my friend :D. I just took a wire brush to my brake calipers and pads to clean them up. I was shocked with 78k that I still have almost 50% pad left. I thought I needed new ones.
misfit77
For those with hub problems did you have any unusual tire wear?
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I did not. I rotate my tires often and discount tire does a great job of balancing them. 50000 miles on G2 terragrapplers with plenty of tread left.
RamCares
n/a
n/a
Glad you wrote this
Hi chrism1367 and misfit77,
We are sorry to hear that you are both experiencing this. If you would like to have your dealers address this concern, please send us a private message and we would be happy to offer an extra layer of assistance!
Alex
Ram Social Care Specialist
C
chrism1367
Just updating this thread, it ended up being my pass side hub bearing. Replaced and is quiet and smooth as ever. That hub was seized on there so bad, had to take a 2x4 and wedge it between old rotor I put on and the frame. Turn steering wheel and finally broke loose. Now waiting for driver side to go lol
