canders13247
Hey everyone, I'm hoping i can get this solved soon. Here's my problem:
The other day i went to go through some light mud and i was in 2 wheel drive and i started to loose grip, so i went to put it in 4wd. The 4wd light came on and when i gave it some gas i heard a clunking noise coming from under the drivers seat. It sounded like a bad U joint. Later that day i got under there and i grabbed the front drive shaft and moved it up and down and to my surprise it moved a lot. At first i thought it was worn U joints at the transfer case. Well, today i pulled the drive shaft off and found the U joints have no play, it is actually that H flange thing. How can i go about fixing this?
