Front Driver side tire sticks out more than passenger after bilstein 5100
MadMatt6-9
Kitchener Ontario Canada
Just did the 5100's my self and I made a huge mistake that might help. I installed the lower spring mounts upside down. I did it on both sides so my truck was out of wack both ways but if you installed one upside down ant the other correct, it might give you one wheel sticking out more than the other look.
WilliamS
Tampa FL
During the alignment you can adjust both upper and lower control arms. If say one side was adjusted in on upper and lower, they could get it straight, just the same as adjusting both upper and lower out. This can add almost a full inch of difference.
JB1
Houston, Texas
No adjustment on the upper
WilliamS
Tampa FL
Wait, really. That’s right I would need aftermarket upper.
sbarron
Wasilla, Alaska
So now OP hasn't been here since Wednesday... still working on it, or... found his self-install problem and now won't 'fess up?
WilliamS
Tampa FL
Likely a smoldering pole of steel. Gave up and torched it.
JB1, I think your dead on.
Addicted2fishing
Durham region
HEMI 5.7
I’m gonna say it’s the left upper-lower delta flange
50BMG
I'd bet it was his Johnson Rod that was out of whack...
It's ALWAYS the Johnson Rod when something unexplainable happens...
Rader
In the Montana Rocky Mountains
3.0 Diesel
IF it isn't caused by an assembly/install blunder the cab body mounts could have been tightened with the cab front off center. If the left tire sticks out one inch and the tire on the other side is flush loosening the cab mounts and moving the cab 1/2" (ONE HALF INCH) to the right would center the cab.
Lucy Girl
Military, Army Veteran
Mt. Vernon, Texas. 75457
3.6 V6
I can’t believe that shocks could do that. Sucks hate it for you. I have 4 5100’s
But I have a 2500. Wish you luck.
JB1
Houston, Texas
Hell yeah, wait................what? :shakehead: :lol:
50BMG
Nothing a few 40 weight ball bearings can't fix though...
It's ALL ball bearings nowadays.
:gr_grin: :ROFLJest:
