Front End Suspensions Squeaking
LS5DodgeRam
South Florida
4.7L v8
Hey guys
I know that there are a few threads regarding this issue, I just don't have the time to look for them right now. I have a horrible squeak coming from the front suspension, and am completely lost as to what is causing this. really what I am asking, is that if any of you guys had this problem, and got it fixed, what part of the suspension was it that you needed to replace? and for anyone's input, what do you think could be the problem?
Thanks in advance!
Chris
HolyRamBatman
Deep in the Heart of Texas
If your not sure what it is, you can spray a lubricant on one thing at a time on the front end until it quits. Then fix or replace it.
What noise are you hearing and when?
Birdman-68
New Baden IL
I had a really loud squeel, and it turned out to be the wheel bearing. Had to replace the whole assembly.
LS5DodgeRam
LS5DodgeRam
South Florida
4.7L v8
how much did that run ya? and I'm replacing my entire front end and including a 6 in lift kit from rough country!
Birdman-68
New Baden IL
I had it done by a local mechanic and the hub was $265.00 and the labor was $65.
LS5DodgeRam
LS5DodgeRam
South Florida
4.7L v8
i found the problem, it is my lower ball joint, i sprayed it with oil and now there is absolutely no squeak!
