Front pump leak
Tommythegun
5.9 L
I have a 1995 Dodge Ram 1500 with the 46rh tranny in it. It started leaking the other day so I pulled the tranny to replace the seal. Once I pulled the seal out I looked in there by the shaft and saw a piece in there with two nipples that look like they could be set screws. It was really loose and I could move it all around. I was just wondering if it should be loose in there or if I should take the pump apart further and tighten those up or not?
auskip07
s
s
Maybe someone in a transmission shop could answer this better.
