front sway bar bent CANNOT find a replacement
zeustheram
North Caroolina
5.9 360 V8
so my front sway bar is bent and i cant find a replacement plus i have been so confused with the differences on the 94-01 front sway bars on v8 gas ram 2500's
Z
zeustheram
North Caroolina
5.9 360 V8
well when i bought the truck it had been hit on the passenger front and where the sway bar bends it bent and it keeps snapping end link after end link
Merc225hp
NA
truck
gas
The differences are in the ends and the links and how they attach to the front diff. Any bar from 94-98 should fit for you. To bad you are so far away as I have a spare bar here you could have.
Z
zeustheram
North Caroolina
5.9 360 V8
i will definitely check out rockauto. i bought some new end links that are adjustable and are for 94-01 dodge ram 2500 only problem is they wont work because the bracket on my front dana 60 axle in the front makes it where the end links are to long and wont work. i can post a picture if that would help with seeing what im seeing
BoBoway4
