Front turn signal & sub swap
WranglerToRam
Robinson,Illinois
5.7L hemi
Hello, I have a 17 Sport and my front right turn signal is out. Is this a dealer serviceable only fix like my OM says or can I tear into and replace the bulb myself? I have the Alpine system and I am just curious can I just easily swap out that subwoofer for an aftermarket one? Not the entire box just the speaker itself?
NJMOPAR
Older and faster
ELizabeth, NJ
If it's a 3157 bulb you can replace it yourself. If it's factory LED then I don't think so.
You have to remove the front grille & remove the headlight assembly to access the back where the bulb sockets are.
As for the sub, you'll probably have to splice into the factory connector which is proprietary.
