Hello, new to forum from Packer country. Got a problem.
My poor old ram isn't used much, just to pull my boat and my car hauler trailer. Only has 69K miles after 14 years. I think I get more problems from sitting around then I do from driving it.
So, I have a 2003 Ram with a 5.9 gas. When started it miss's coughs, backfires, etc. After a bit of flooring the gas pedal it clears up until the next time I start it. And cold or warm starts don't matter.
No codes on my cheapo harbor freight code reader.
Ran a bunch of gas dryer thinking water in gas, no help. New rotor and distb. cap cause they were a bit green inside.
Book talks about vacuum, I have 15in at idle and 20in with a tiny bit of throttle, nice and steady.
Book also talks about fuel pressure so I rigged up a gauge from an old Freon adapter fitting, and a very old vacuum/fuel pressure gauge. T the rail fitting I'm getting 40psi, all the time. all RPM's. Book says 47 to 51psi.
Can being 7 psi low cause all my problems? Do I need a new $250 fuel pump? $750 at the dealer.
Retired here, money is tight.
