LeesEvoX
- Oct 29, 2017
- 1,652
- 2,216
- Location
- Houston, TX
- 2020
- Hemi 6.4l
I'm sorry. Haha.What is TIP start?
Glad to hear it worked out. I got to do the fuel level sensor soon, I just count my miles for now.
So since I ****** this up so bad. I'll just summarize how I think would be the easiest way to do the fuel pump.
1) have an empty gas tank....
2) jack up rear of truck, and put on jack stands.
3) take off driver side rear fender liner, remove tail light connectors and drop through bed.
4) remove the 3 16mm bolts on driver side of bed, loosen 3 bolts on passenger side
5) take out the filler neck
6) lift the bed up a little bit. Maybe like 4".
6a) I only do this to get easy access to fuel lines/connectors on top of tank. So not necessary, but worked best for me.
7) disconnect 3 lines from tank towards rear of truck.
8) remove fuel line. And electrical connector on fuel basket.
8a) there is also another fuel line on the frame running down driver side. Along with a last electrical connector on side of tank, next to drive shaft. kinda under the heat shield.
9)I used a motorcycle jack to support the tank (which was perrfect). But support tank, and remove 2 muts for the tank straps.
10) remove tanks straps, and drag that sucker out!
Look at that. 10 steps. It seems so easy now. Haha
Sent from my SM-G950U using Tapatalk
