Fuse tapping
Rick8269
St. Peter's, MO
5.7L v8
I have a 2015 1500 crew cab outdoorsman and i recently began upgrading the sound system. I decided to stay with the factory head unit. I ran the remote wire to my fuse box under the hood using a fuse tap with 20amp fuses. My amplifier turns on when the doors open witch makes my subs kinda go nuts until i turn the key. Am i tapping the wrong fuse? And which one is the right fuse?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You want to tap something that is ACC power. The cigarette lighter plug is ACC (turns on with the key).
chopperman1
2018 Rebel
5.7L HEMI
You typically don't want to just "turn on and amp" with acc power. You want the trigger wire to be controlled by volume output of the radio, that way the amp is not on when the radio is not on. If your amp and radio combination does not support this then you want an acc fuse, not the lighter, that triggers when the doors are opened or some models when an unlock happens.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Interesting, mine only works with the key in...I wonder if their is a setting in AlfaOBD for it?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If i recall correctly, on some year Rams
The fuse for the cigarette lighter, is a 3 pin socket or whatever its called
The fuse itself is 2 pin
in one position the cigarette lighter is Always Hot
move the fuse over to the other pin & it becomes hot with the ignition
Like the 2014 Ram fuse diagram, check fuse 90/91 as an example
9020Power Outlet (Rear seats), Customer Selectable
91
92​
9320Cigar Lighter
