I'm not sure if it's the same type of issue but I imagine the 4th gen is similar in design to the 5th gen.I'm here because this issue just emerged on my 2018. It started happening little over a month ago. Every pump: Chevron, Sam's Club and Costco. Doesn't matter the angle, depth or speed. (twss)
Called my dealer today and was placed on hold. They finally asked me if the service manager could call me back. I said sure. And no call. No surprise.
I just have a strong feeling that if I take it in for service, they'll keep my truck for 2 days and nothing will have been solved. This, based on reading that pending class action suit. FCA doesn't even acknowledge the issue. So why would the dealership spend time & money on it. They couldn't care if I took an hour to fill up.
I was really hoping I'd find a "here's a simple fix" post.
Sounds like that is a pretty good dealer, quick repair.Hey all, just wanted to share my issues and the resolution. Once the weather started to warm back up here in Vegas, I had issues at the pump. I could hear the filler neck fill up and then shut the gas pump nozzle off. Rinse and repeat. Didn't matter the pump, angle, rate of flow - nothing helped.
Cut to 4 weeks ago, took my 2018 Ram 1500 into the dealership, they looked at me crazy. Then he called me back and apologized. Mechanics could recreate issue AND there was a brand new Technical Service Bulletin out addressing it. I don't know the details. He said it mentioned a bad or malformed tank causing vapors to build up.
The fix: replace the enter gas tank.
Which happened just this morning. They also had to replace the fuel pump because they broke a T-fitting on it when removing the original tank.
I just pumped in 3/4 a tank without a single pause.
Hope this helps.
My Dealer replaced the Filler Tube according to the Service Bulletin. It did not fix the problem. It helped slightly but did not Fix the Problem. I'm now waiting for the Factory to "get Back to Me/Us". It's been a week since they replaced the Filler Tube with no success.Started having this problem a few weeks ago. I have a 2019 Ram 1500 and will be taking it to the Dealer soon. Will respond with what the solution.
That's where I'm at.Anyone have the "Fix"? I'm waiting for the Rollover Vent to be "The Fix"...
I'll agree somewhat. I'm sure that the pump guns could be better but my truck is the only vehicle I've driven in the last (at least) 15 years that this has happened to.I actually found a gas station with the older style pump guns and when I filled up this weekend it didn't click off at all ...
I am starting to think that it's really not the evap system or the tanks but the pump guns at these gas stations that are very sensitive ... they have a sensor in them that has to be replaced if it goes bad, I asked a guy who was servicing the pumps at a newer gas station and he said the new pump guns are just horrible and they have no time to maintain them which is why these pump are causing problems for many newer trucks and cars ...
So there you have it .... this is actually not rally FCAs fault but more the new pumps that are replacing the older ones ...
