Gearing
I have a 2012 1500 (6 speed) single cab, and don't know what gears I have. I have stock 33 inch tires and plan on keeping a tire that tall. So my question is where can I find my gear ratio? At 6k rpm in first gear I am going 50 mph if that helps at all, just trying to decide to re gear or not. Thanks!
TylerB
FL
If you are indeed doing 6k at 50mph, then by my math you have 3.92s.
4.56s will definitely make your truck more, feel lighter off the line, and improve overall driviability with the 6spd trans. The shorter gears will even reduce strain on the trans. The only negative would be a slight 1-2mpg loss on the highway depending on speed.
slightly_low_ram
Thanks for the info, I figured that's what I had but wanted to be more sure before I bought 4.10 or 4.56 gears.
Pull Ya
Cedar Creek, Tx
The difference between the 3.92's and the 4.10's in very little. If you are set on going to a lower gear I think the 4.56 will give you a significant change in acceleration. Matt at Moe's Performance has had a lot of experience running the same gear ratios you are talking about. You might give him a call before you invest in any new parts.
Jay
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
- Go to this website --->
https://www.dodge.com/webselfservice/dodge/index.html
- Click on the link down the left side of the page that says "Equipment List"
- Enter your VIN in the smaller search bar and click search
