Gearing
2000.2500.ram
12v cummins
I just found out I have 3.55 gears. And I'm running 35" tires. Though I had 3.73s but don't. So I wanna get these switched out. But I don't know whether to go with 4.10s or 4.56. But I drive highway alot. 60mph. Wondering rpm with both and do I need a ring and pinion for front and rear. Just want some thought
tommyboi87
houma louisiana
5.2 Magnum
I can't comment on tire size, but you definitely need to regear both axles. I've got 4.10 on stock rim and tire height. I'm under 2 grand at 65 though.
Sent from my SAMSUNG-SM-G925A using Tapatalk
2000.2500.ram
12v cummins
Ok that's good enough for me. I know I had to do both. But not real shore why I asked. Guess I was suspecting a no so I didn't have to spend as much hahaa but thanks. Really was wondering about highway
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
I have 4.10's with 35's. Honestly couldn't tell you my rpm and speed correctly since my speedo is off from my tires lol at 2,000 my speedo says I'm 65 but I know I'm going faster than that when I can keep up with interstate traffic...are you referring to the gears in your 360 or 12v?
BBartow
New Port Richey, Florida
5.9L Magnum
Yes this is very important
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
Its a 2500 judging by his name, so he doesn't have a v8 if he has 3.55 gears.
V10 or diesel-3.55
v8 2500's-4.10
Sent from my A0001 using Tapatalk
1SilverBullet2
North Dakota
He has a 2500 with a 360 that has a turbo, that's why I was asking while his profile says 12v. But yes I've seen 2500 360 w/ 3.55's as well.
tommyboi87
houma louisiana
5.2 Magnum
Just for the record, I meant to say under 3 grand. This phone changes everything I type.
Stegs
1998 Dodge Ram 1500 4x4
5.2L 318 C.I.
i have 315 tires, which i think is 34" tall or close too
anyway, i have 4.56 gears and a spicer limited slip in the back
if your going to spend the money, go 4.56 . Its like 4.10s on steroids!
4.56 gears make it easier for your motor and easier on your drivetrain.
plus its fun sometimes to throw like 225 tires and go out and do some hooning! :naughty::flipthebird:
Merc225hp
NA
truck
gas
I've seen lots with 3.55s
Not with a v8. V8 was 4.10
I have had a few gear ratios and tire sizes. 4.10 is still my favorite for my speeds, roads and how my motor is built.
Merc225hp
NA
truck
gas
No **** they where 60's I'll look into it but I have not seen this.
BBartow
5.9L Magnum
Sorry didn't want to sound like an ass for contradicting you.
I believe newrammer said he has 3.55s and his is a V8 2500. Also pulled the vins off 2 trucks on craigslist that were V8 2500s. I know build sheets aren't always reliable considering they call a rear D60 a 200MM axle, but here they are.
http://www.dodge.com/webselfservice/BuildSheetServlet?vin=3B7KF23ZX1G166696
http://www.dodge.com/webselfservice/BuildSheetServlet?vin=3B7KF22Z5WG146803
2000.2500.ram
12v cummins
Sorry guys it's been awhile. But its a 360. Gna change subject a little. Saving up for the front gears now. But my flexplate took a crap on me. So I was gna go ahead and install a shift kit. What ones do u guys recommend?
