gears
4.76speed
hixson,tn
ok so i got my trucks build sheet today from dodge. it has 3.55 gears. and also now has 275/55-20 where it was 265/70-17 stock. and it need more go. so gear chage is in order. will 4.10s be a good pick since i cant find 4.30s for the 9.25 and i worry 4.56 might be to much. anyone else have an opion?
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
4.10 is a good in between for 3.73's and 4.56's. I wouldn't go 4.56's unless you plan on running bigger tires than that. Stay under a 33 with 4.10's
SmokedRam
Zephyrhills, Florida
My buddy is running 4.56 with his 4.7 with 20's...he really has to baby it on wet pavement sometimes and his is a pre 08 too, with less power and tq...I agree with Brandon...
4.76speed
hixson,tn
thanks guys. thats what im thinking to. think it will be a good improvement? sorry to ask i have always built much lighter mustangs and i know what going from 3.08s to 4.10s in those cars will do but in a truck that weighs 1300-1600 lbs more just worndering if it will be close to the same diff
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Its a noticeable change from 3.55's to 4.10's. Some have regretted including myself for not going up to 4.56's straight away but to each their own. In terms of the wet pavement you just have to be in touch on how your truck responds and adjust your pedal response to it. If it means egg shelling to the speed limit then so be it.
SmokedRam
I can find my friends burn out video with his 20"s and 4.56's if ya wanna see...it's not bad at all for a pre 08 4.7...lol
