Gen 3 rims on a gen 4
redvetram
Idaho
Pentastar V6 3.7
why wouldn’t a wheel from a Gen 3 1500 fit a gen 4 1500?
Same lug pattern. same lug size. The only info I can’t seem to nail down is offset.
Basically want to replace my 17” spare rim with a 20”. All the ones I can find are specified for 2002-2008 Rams, but I can’t figure out how they differ from the 2009-2018 wheels.
Fast69Mopar
Here are the stock specs for the
2009-2018 factory 20" wheel...
Front: 20x9
Offset: +19mm (0.748")
Backspacing: 5.7"
Bolt Pattern: 5 x 5½ (5 x 139.7)
Rear: 20x9
Backspacing: 5.7"
The bolt pattern is the same for 2002-2019 Ram 1500 5-lug trucks. (except 1500 MegaCab)
2020 will use the new 6x5½ bolt pattern.
U&A
2016 3500 SRW
6.4 HEMI
Just keep an eye on load ratings of the wheel if you do towing close to max capacity.
Sent while firmly grasping my redline lubed RAM [emoji231]
kurek
Northwest
I have 2003 17x8" wheels on my 2015 4wd 1500 - can see it in my avatar.
2002dodgenvhelp
