I asked this question in another thread about adjustable rear sway bar end links and could not get an answer . I am thinking about the GF 2/3 kit for my 2014 express 4x4 reg. cab . If I were to go with adjustable end links would it eliminate the drilling step on install to relocate the stock sway bar ? In other words after truck is lowered use these in stock mounting point and adjust sway bar level ? If so which size should I get ? On another note after install do you guys recommend replacing front end links as well ? If so what part# end links do I need ? If I to do it I want to do it right .. I like the idea of not having to drill my truck if I don't have to .. Thanks for any info . -Gary
