glow shift sucks my balls
ramhunter9
P-Star Jeep Wrangler
well got the gauges in , a trans temp , and a AFR gauge .
well would have been nice if the bone heads from glowshift would have told me i needed a adapter to hook the trans temp gauge to my trans ....
and would have been nice for them to let me know the AFR gauge doesent work on a HEMI because the o2 sensors on a hemi are wide band .
soooo i have to go get a single wire o2 and **** , and install that ....
so in all they look sharp and pretty , but i cant use them till i go get more parts .
**** glowshift .... last time i deal with them . you would think they would tell you at check out ,,,,hey your engine needs this for install ...**** heads .
but like i said they look cool , just got to get them done .
ramhunter9
ramhunter9
no pics ,,,, not all hooked up ...this months mods sucked .. new sub ...but need new amp
pod .... no screw till today ....gauges ....incomplete ...
where is my ****** beer
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
dude just get a wideband guage
ppl spend a **** ton of money to get wideband access. and they are hella more accurate
RubberFrog
Narrow band ad is completely worthless. It's like buttons on a doe.
ramhunter9
ramhunter9
im not putting it in **** it .. now what to put in ??
ramhunter9
ramhunter9
cheap AF ... im just filling a hole .
RubberFrog
Don't go cheap. You'll regret it later. Take a deep breath, take your time, and do it right.
ramhunter9
ramhunter9
ok ... i would like to keep what i have . the AFR gauge . to make that work i need a narow band single wire o2 sensor and **** . anyone know if just any single wire o2 will work ?
RubberFrog
You don't want narrow band. That's for poser ricers. You want wideband.
ramhunter9
ramhunter9
ok well dont give me any help ...lol i have it installed just need to figure out the single wire o2 thing ? the single wire from the o2 goes into the gauge correct ?? well duh ... the question is can i use any ol o2
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
the o2's from the hemi are most certainly not wideband. the green wire coming out of the o2 is the one you want to tap into. if you're not sure, use a multimeter while the truck is running and find the wire showing a variety of readings between 0-1v
ramhunter9
ramhunter9
i called dodge and glowshift . both said the hemi uses wideband o2 sensors that are 4 wire ... 2 white 1 black 1 gray .
i tapped the gray wire ..nothing . might be the black but i dont want to cut till im sure
ramhunter9
ramhunter9
so if they are full of **** ...what is the signal wire on a oem o2 ?? black ??
ramhunter9
ramhunter9
yup black is the signal wire ....going to try that out ..in the AM
max WTF are you talking about ?
