glow shift sucks my balls
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Drink alot and it will look cool. Are you gonna do anything with the truck to need a A/F?
ramhunter9
ramhunter9
P-Star Jeep Wrangler
NO i need the trans gauge that i put in but since i got a deal on a dual pod i needed something to put in it thats all .
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
See if you can send back the a/f gauge and get their wideband they offer if you want one, if not get an oil pressure gauge.
ramhunter9
ramhunter9
got a new one should be in this week also the old amp was sold last week max
and ken , if black is my signal wire off the o2 im good . we will see
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Sounds good I wish I could tell you for sure on that black wire... Is it a sweep gauge or a digital read out? Either way be careful not to stare at it while your driving. Everyone that drives my truck is fixed on my wideband while driving lol.
ramhunter9
ramhunter9
both are sweeps . im old school
truckin151
2013 sport
Um thats the first time I have heard that the hemi's have wideband o2's....
cmns2500
p pumper
from all my readings on the diesel forums i'm on glowshift gauges suck donkey balls...i bought a set w/ pod but never installed em so i can't say personally what they are like
Danimal77
Pontiac, IL
should have gotten the Aeroforce scan guage......it's Big Pimpin'
ramhunter9
ramhunter9
Fyi i called 3 different dodge service departments . 06 and up are wide band o2's . 05 and under narrow band .
Sooo... I need a single wire o2 narrow band
truckin151
2013 sport
RH you do NOT want a narrow band O2. You WANT the wideband. So if you already have a wideband in there all you need to do is tap the thing with the appropriat gauge. If your gauge only reads narrow band you need to ditch it for one that reads the wideband.
Eaton
Just for clarification, if we have an 06+, we only need a wideband gauge to read AFRs? We don't need to get a new wideband O2 sensor; we can just tap into one of the existing OEM O2 sensors?
Captain McGillycutty
Maumelle, Arkansas
2011 Power Wagon
I agree glowshift does suck. I just got my air pressure gauge for my horns in from them and the lights on it are so dim at night you cant even see the gauge and then i had the same fitting problems you did.
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
ditch the glowshift RH. quit trying to go for looks over function. its only costing you more money.
If you want the dual gauge setup, get Autometer Trans temp and an Autometer AFR guage. they arent that expensive, and they're the best guages out there
ramhunter9
ramhunter9
cap... my guages are bright as hell
AF ... im not going for look or function ...im just bored
ramhunter9
ramhunter9
yes all you need is the gauge , but most all kits for wide band come with a new sensor , so why not
Reticle918
