got LSD and Gear???
meadows
ft hood
i just bit the bullet and got a LSD with 3.90's. Does anyone have a specific list of what else needs to be purchased for the install? Bushings, bearings, seals, gaskets, etc.... thanks fellas. matt
Razzaa
If you have a 4wd I think you need a front end............
09SMOKINHEMI
TEXAS
Just had mine done a few weeks back. All i needed was the gears, lsd, master install kit and fluids.
sent from my Samsung Galaxy S3
M
meadows
ft hood
ok. allow me to elaborate...2wd, 2012 so I have the ****** zf diff. have already made a few calls and am trying to get exact pn's.
Jerseymike
You just need the side bearings, 3 qts synthetic gear oil with lsd additive, and a tube of sealant for the diff cover. Get it done with someone that has done a lot of gears to get then set up correctly. Most of the parts in the master install kit wont work on the ZF.
Here is the part number for the bearings. Just put it in google and you can find them pretty easily. 68067933AA
M
meadows
ft hood
follow up on install
as stated above, this is my gear and LSD install follow up. Im breaking in the gears (500 mi) and just taking i easy. Lite acceleration is decent. It does feel a little more "connected" to the throttle. Overall i feel that this will be a good base for my future mods. The price for parts and install was not TOO bad but i was tired of crap for traction in the rain and one wheel peels. Matt
