guages wanted
Status
Not open for further replies.
AJMAG
new jersey
lookin for:
boost pressure
rail pressure
trans temp gauges for an 04.5 5.9 cummins
text for fastest responce 973 459 2347
Rogan68
Lancaster, TX / Winchester, VA
6.7L Cummins G56 DRW 4WD
I assume you're after a wideband Air/Fuel Meter? Otherwise, your run-of-the-mill narrow-band meter will be totally useless, especially on a diesel, since the stoich marks are different from gas.
ramhunter9
P-Star Jeep Wrangler
Get a programer that monitors all that plus some ... My quadzilla with the PV2 does this . Only 850 with all the hardware you need , then get a nice mount for it and done !
I have set up for .
Boost
EGT
Fuel PSI
Trans Temp
IAT
Oil temp
Oil PSI
Water Temp
And a few others
ramhunter9
And the other benefit ... well added power and Tq , **** settings on the fly , powerbands from 0-10
ramhunter9
WOW ... you got a deal Rick ... awesome
AJMAG
AJMAG
new jersey
i think im gonna go with the smarty so gauges are needed.. if you can lock or delete this thread or whatever you wanna do.. im not really lookin for some at the moment anymore (saving for a trans first)
ramhunter9
its cool we will leave this for reference
AJMAG
AJMAG
new jersey
back up top. lookin for a boost pressure,trans temp,and rail pressure gauge for an 04.5 5.9 cummins
ramhunter9
Get a PROGRAMER with built in parameters
ramhunter9
Smarty tarty ...
You need a programer like bully dog or adrenalin .. one that reads everything on a display and gives to more HP
Status
