Guide to Leveling & Wheel and Tire Sizing for 06+ 4wd Ram 1500's
DRkNESS
South Jersey
I own a set of 20x9 ET 25 Hellcat wheels. I want to put LT295/60 tires on. I'm currently running Bilsteins on all (4) corners with the fronts set at 2.1. Is this doable without spacers, or should I stick with an LT 275/60 tire ? I don't off road or use it in the woods or beach, yet I want a slight aggressive look with these wheels. What say yee folks ?f53103bbaff33ca13105b68f0bd54f4d.jpg38653d5fd809d53502bbf66c64694c3e.jpg
Kab
I want these same wheels for my factory suspension 16' 1500 in a 22x10 with a +25 offset and the seller guarantees they'll fit with no spacers or mods and no rubbing with 305/40 wheels and I just don't see how they won't rub. Wish I could figure it out so I can order everything but I'm lost.
DRkNESS
South Jersey
That's exactly how I was with another set of wheels. I was guaranteed that they would fit. I was also told that if I mounted a tire on it even to test it, I wouldn't be able to return them. I know a lot of these installs are done by trial and error, I just don't have the patience to be THAT person. One thing that I've found, even though the trucks may all say the same, not all 1500's are created equal.[emoji848]
Reactions: Kab
Kab
Yeah I dunno what to do, I hate to spend a few grand on a whole wheel and tire setup and it not fit. I found another wheel I like but the hellcat wheels look amazing.
quietpeen
2021 TRX
Hellcat
What is the offset on those wheels. In the other thread I figured you were talking about stock wheels
Kab
The offset for his wheels are +25
quietpeen
2021 TRX
Hellcat
On a 4x4 I also don't see how.a 295 tire wouldn't rub let alone a 305.
Kab
I'm having the same issue, I want wheels like his with +25 offset but 22" and I want to put 285/45 tires but I don't know if they'll rub. Some have told me they won't and others said I need 3/8 spacers. I'm stuck
DRkNESS
South Jersey
Just to play it safe, I'm going to stick with a 275/60 tire and deal with it lol...
Kab
Let me know how they fit. That +25mm offset is a ball breaker.
DRkNESS
South Jersey
Will do, the good part is I only paid $800 total for these wheels so if it doesn't work no loss. Also if it doesn't work, I've already contacted a company about doing the wheels that are currently on there in " black chrome " which is what I really wanted.
14blackouthemi
North Jersey
I run 22x10 hellcats with a 305/45r22. I use 3/8in spacers and have no problems at all. I'm a 4x4.
DRkNESS
South Jersey
^^^.Good to see as I am hoping that a 20x9 with factory sized tires will do. Again if not I know how to go back to my original wheels. Just to make sure, I've grabbbed a set of oem tpms sensors to add to these wheels so that my original ones can just be bolted back on if needed. :)
brandonjansen
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
As quietpeen stated, that setup won't work without spacers. You'd need to either stick with a 275 wide tire or add a set of 10mm hub centric spacers from Motorsport Tech.
DRkNESS
South Jersey
^^^. Just the person whom I was hoping would join in with his knowledge. Knowing that I don't really want spacers, I can accept sticking with a 275 sized tire. I just want a A/T look without being over the top. Hopefully Toyo will have something that suits that in a 275/60 fitment. :)
R.L.K.
Bristol , Tn.
I agree
CUBS_WIN
2014 1500 4x4...im istalling mevotech uca on front...after installing those i was gonna use spacers as well...will i still have ball joint issues and will i be able to use 35x12.50x17? I know people use bilstien 5100 but i dont offroad at all...just my daily driver. Thanks.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Reactions: Kab
brandonjansen
brandonjansen
Yes, you could still have ball joint issues with running leveling spacers with the Mevotech UCA's. Multiple people have had failures with Mevotech's and spacers. This is why I recommend Zone UCA's if you are going to spend the money on an upgrade.
Bilstein 5100's are still a better option all around.
For the tire fitment, you won't be able to run 35x12.5r17's on stock wheels. You'd need wheel spacer or aftermarket wheels that provide more clearance on the suspension side of things.
CUBS_WIN
If i do bilstein 5100 front shocks will i need upgraded uca
R.L.K.
Bristol , Tn.
The short answer is no , unless your ucas are in bad shape now .
bbramer0820
