Gun Rack?
kansas
What is the best made gun rack that fits a 2021 Power Wagon. Would like to have one that holds at least 2.
MADDOG
Living in a Firepit
Type of gun?
Preferred mounting location?
Excellent questions. Exactly what came to mind when I read post #1.
OP, we need a bit more info. Oh, mounting over the rear window may not work as the window seals and available channels are just not the same as they were back in the day.
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
What kind of gun rack you want, one for rifles? Just gotta do a google search. I found all kinds of gun racks. I'm sure your PW is a crew cab, correct? I don't think they make a PW in a regular cab or a mega but there's this one that mounts to the roof over your head between the tops of the B pillars but after a quick chat with that site, they said they can't verify that it fits anything other a 2019-2021 Ram 1500 but unless I'm mistaken, all the crew cabs ought to be the same whether its a half-ton or a HD. You'd just have to get with the manufacturer to verify it would work in your PW.
There's this one too that mounts on the floor behind the driver seat.
This one mounts between the front seats off an apparatus that hangs off the top of the seats.
Just have to look around.
M
kansas
The ones I have found online mount between the posts between the doors. I am tall and there is not enough space for one above my head. I was thinking if I could find something similar that would mount farther back above the rear seat it might work but I haven't seen anything like this. as far as types of guns ar, lever guns, pump shotguns I would like it to be versatile.
M
kansas
Apparently the word for :to cause to rotate spirally about an axis is a naughty word.
UTAHPWRWGN
Hurricane, UT
6.4L Hemi
About to be released...
SeppW
Northern VA
Hemi 6.4L
Long gun/Shotgun? If you have a RamBox, there is a kit. There is this: https://www.du-ha.com/catalog/produ...500-3500-quad-cab-crew-cab-03-17/category/71/ It does have application limitations. Unless you're looking for something for quick access, a few other companies make such things. Not a whole lot of room in these cabs for much of anything. I use locking gun cases and place in the RamBox and on back seat and throw something over them. Transporting firearms is another factor to consider too. We are in perilous times.
Grand Mesa
Need safes for the ammunition too, it's in high demand.
Dean2
Near Edmonton
They also make a version of this that is completely enclosed as part of the seat covers so you can't see the guns from outside. Makes it look just like a normal back on a set of seat covers. There is also a version that has a single gun sleeve on the front of the seat cover, right behind your legs, you can slide it out from either side, picture below is a one sided version, when you step out of the truck. Best solution I have found for out of the way but still handy.
Phillyrube
Flatistan
Just some upfitter mounts. My old agency had a rack that allowed storage of a shotgun across the edge of the front bench seat. Probably would not work with buckets..
Rifle holder
56PW17
Pa
Well talked about topic in other posts. I’m sure a few guys will put some pics in for you to see but you need to be more specific.
When I owned a PW I had a few places for different items.
There is a company for a lock box that mounts under the /20 seat of you don’t have buckets, sure they make them for the center console anyway but that’s good for hand guns and what ever.
behind the rear seat is good for long gun storage if you have the seat mod done and don’t have baby seats in your truck. Not good if you need it while driving.
Besides that how visible do you want to be? You can put a gun anywhere in the truck ect..
I carried in those locations and others before. I also have a decked system and when I’m working my seasonal business will have a dozen of so in them at a time.
Lots of option just need to know what you are really looking to do ?
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
They also make a version of this that is completely enclosed as part of the seat covers so you can't see the guns from outside. Makes it look just like a normal back on a set of seat covers. There is also a version that case a single gun sleeve on the front of the seat cover, right behind you legs, you can slide it out from either side when you step out of the truck. Best solution I have found for out of the way but still handy.
Any more info on this? With the back mod I did, this would be fantastic!
Dean2
Near Edmonton
Also, LLBean used to carry that model too. If you Google Seat Cover Gun Carrier a whole raft of options will show up. I have had mine custom made locally for decades by the place that makes the Western Saddle Blanket type seat covers but they are now readily available commercially.
westernexplorer
USA
Etorque V8
There’s this one that’s for under the back seat. I believe this ones for a 1500 so you’ll need to make sure it matches your model. Comes with a few gun hooks and they claim it’s good for one rifle w a scope and I guess another rifle/shotgun with no scope. Haven’t tried it yet so I can’t vouch but seems to be the best option for me based on research.
Jay Peazee
Colorado
5.7 Hemi 8 speed
Check legalities for your home State, gun racks have been made illegal in some areas, fyi. Also, depending on the firearms, Cabelas always has a selection of interior based racks for pickups as well as the awesome finds already posted here (that MOLLE rack is tops!!)
