melvingeraldmesse
What is the best made gun rack that fits a 2021 Power Wagon. Would like to have one that holds at least 2.
Type of gun?
Preferred mounting location?
Long gun/Shotgun? If you have a RamBox, there is a kit. There is this: https://www.du-ha.com/catalog/produ...500-3500-quad-cab-crew-cab-03-17/category/71/ It does have application limitations. Unless you're looking for something for quick access, a few other companies make such things. Not a whole lot of room in these cabs for much of anything. I use locking gun cases and place in the RamBox and on back seat and throw something over them. Transporting firearms is another factor to consider too. We are in perilous times.What is the best made gun rack that fits a 2021 Power Wagon. Would like to have one that holds at least 2.
They also make a version of this that is completely enclosed as part of the seat covers so you can't see the guns from outside. Makes it look just like a normal back on a set of seat covers. There is also a version that case a single gun sleeve on the front of the seat cover, right behind you legs, you can slide it out from either side when you step out of the truck. Best solution I have found for out of the way but still handy.
Any more info on this? With the back mod I did, this would be fantastic!
Check legalities for your home State, gun racks have been made illegal in some areas, fyi. Also, depending on the firearms, Cabelas always has a selection of interior based racks for pickups as well as the awesome finds already posted here (that MOLLE rack is tops!!)What is the best made gun rack that fits a 2021 Power Wagon. Would like to have one that holds at least 2.
