guys that are 3/5 drop
joeg45
Katy, Tx
I just re dropped my truck to 3/5 and haven't gotten my alignment yet but was wondering could they fix the camber or would I need a camber kit
If I do need one what kit do I use I haven't had any luck on finding one except for one called trail master universal shim kit Amy help would be appreciated
UNBROKEN
2012 Ram R/T
My camber came back into spec great...caster is right on the outside edge though.
WhiteExpress
Midland, TX
Just because UNBROKEN was lucky enough, does not ness mean that your truck will be the same. The 'acceptable' variances in the frame are alarming large to me.
I had issues getting one side into spec while the other side had no issues.
Explain THAT one! We ended up grinding out the alignment slot ever so slightly to allow for more adjustment (This was on my '99, btw). Worked flawlessly.
blackout11
alpharetts GA
2011 R/T
Dont think there is a kit unless you get the balljoint one for like 275
joeg45
joeg45
Katy, Tx
Well that's a sigh of relief
How did you do the 3/5 drop?
Cut half a coil up front one on the back on beltech I don't know about factory or mcguaghy
Well hopefully that's not the case never know though
Well then now I hope the alignment will work out fine I'm going tomorrow after work
joeg45
joeg45
Katy, Tx
Well just got done with my alignment every thing was put back into spec except the camber :/ it was around 1.7 on both sides and the specs were .4-.6 so now I gotta figure something out the fix that
TylerB
FL
That's where I am right now. I think I'm gonna slot the UCA mounts out or make some mounts that move the upper control arms up and out.
joeg45
joeg45
Katy, Tx
Ya I might have to be doing the same thing but I'll work on the rear end a little first since I got the front end to ride pretty smooth now with the alignment just the back is a little bouncy
