MarshRam
- Joined
- May 24, 2017
- Posts
- 2,343
- Reaction score
- 1,652
- Location
- Florida
- Ram Year
- 2014 SLT 4x4, 2012 ST
- Engine
- Hemi 5.7
So I bought a Rove and purchased the hardwire kit for my 2012 ST. It comes with the wired fuses w/ add a fuse. However, there is no fuse box inside the cab. If I want to use the provided fuses/wiring, I would have to drill a hole or two in my fuse box to get the wiring through, because the fuse box isn't going to close properly with wires running between the box casing and lid. I'm absolutely not doing that. So, is everyone tapping in somewhere else? I can purchase or fab fuse/wiring and find a place somewhere else, so no need for help there, but the fuse box would be preferred. I have more than enough tapping in going on around this truck. Seems what they provided is absolutely useless if you can't tap in inside the cab. Am I wrong here?
Edit 7/6/2026: I purchased two Red Wolf harnesses for $20 a pop to plug and play into my auxiliary power outlets. One needed to connect the constant power and the other for ignition power, both necessary if you want to use the cams full capabilities. The fuse location for the constant power in my truck will not hold the fuse adapters they provided in the hardwire kit. One way the lid is in the way, the other a much taller fuse is in the way. I might have drilled and grommet the fuse box otherwise. At the end of the day, got the Rove on sale for $100, hardwire kit for $30 and the two additional harnesses for $40.
