Haveing problems with my 2012 dodge ram 2500 codes p0307
Crg8946
Decatur tx
replaced plugs with igk iridium’s and coil packs found one bad fuel injector replaced it now runs smooth but wondering what I should check the o2 sensors since I had that one bad injector leaking constantly???
Hagar1
Ontario Canada
2012 Ram 1500
If you are going to change the O2 sensors, I'd strongly recommend that you stay away from the junk that is pedaled on Amazon. You will only end up changing them a few days later.
Buy only from dealer or a reputable auto parts store.
I made that mistake and had to change them again.
C
Crg8946
Decatur tx
Thanks for the input I know Amazon not the best for auto parts learned from my past experience I usually go to autuzone
HarryS
Air Force
Clovis NM
I would be more concerned with the cat, than the sensor.
HarryS
Air Force
Clovis NM
NO, but if you had raw fuel in the exhaust, it could damage the cat.
