Header install help
Discus24
Too bad you don't have one of the TV channels filming your saga, you'd be famous by now. Heck, my wife, who doesn't know a header from a headrest would probably be watching. Thanks for letting any of us contemplating this know what we're in for, and I mean that sincerely. Good luck.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Think I will cut bolt head or more off after loosening bolt up holding dipstick tube in with a small cutoff disc. Should be able to back remaining bolt out with fingers & replace with stud & nut. Drain oil & fish mig welding wire thru dipstick tube & out oil drain after all these issues.
Jwithing
Jwithing
STL
Not a bad idea. You may have clearance.for the bottom bolt. I've seen others state they didn't have an issue.
Jwithing
Jwithing
STL
IDK wtf I was thinking... The scope is a pain in the ass to work... If I leave the broken tube piece in there, is it going to cause any harm?
Jwithing
Jwithing
STL
Had some time to get back at it today. Just dropped the oil pan. Had to remove the "structural dust cover" that bolts up to the bellhousing and to get that off, I had to remove the metal plate under the starter. Had to put the pan down and was able to reach right in and pull the little bugger out. Plenty of clearance at the end as you can see from the pics. It was sitting right next to the plug, but in the pan, the plug doesn't sit at the very bottom, so it would have been next to impossible to fish it out. Was worried about the gasket, but luckily it was still on there. FYI, then pickup tube does have an extremely fine screen on it, which the dealer told me it didn't... Now to figure out how to unbolt the pickup tube and get the new windage tray in...IMG_20171223_132618.jpg IMG_20171223_132549.jpg IMG_20171223_133040.jpg
Pull Ya
Cedar Creek, Tx
You should get a gold star or something for all the crap you have had to go through getting those damn headers installed. :(
Jay
Jwithing
Jwithing
STL
Windage tray was tricky to remove... Have to go from the front, unclip the fan shroud, position the oil pan as far left as possible and pull the windage tray out to the right. Requires some jiggling and repositioning due to the pulley and the down bolt for the pickup tube. Waiting for the fiance to get home so I can pickup some rtv sealant, but I got the new one sitting in there ready to go. I feel so relieved as it's been problem free today.
Jwithing
Jwithing
STL
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Jay
Seriously. And it was good you fished that out. Man, I have a cold brew here for you (virtually). Your perseverance will pay off!
Jwithing
Jwithing
STL
Look at the pic closer... Last bolt for the oilpan broke off flush lol
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I have oem gaskets with my BBK shorties. My mechanic hated the job figured it took over 12 hours he lost track just too tight and poor fit. I paid a crap ton to have them done.
Jwithing
Jwithing
STL
Can't get a center punch on it, I'm about ready to slather the entire back lip with rtv sealant
crackerjack1957
Left hand drill bit & screw extractor if drill bit does not back out.
I like to start with center drill to keep hole on center easier.
Plenty of experience, 37 years as a cnc machinist.
Jwithing
Jwithing
STL
Can't get a left handed bit in there with a drill because of the bellhousing. Trying to drill a pilot hole with an extended bit, but can't keep it even close to center
crackerjack1957
Damn, I see, you need drill extensions but not everyone has those.
They also make #2 center drill 6-inches long & smaller drills 12-inches long.
Jwithing
Jwithing
STL
Yeah, everyone only carries a 1/4 inch shank extension, which is too big.... Guess I'm dead in the water again until I can order something
I have a deep pond we can roll your truck into, then we'll all pitch in some money and buy you a new truck with headers already on it :) looks like once you get this bolt sorted out you should be pretty well set. Good luck!
Jwithing
Jwithing
STL
Ha! Not out of the woods by a long shot. The headers look awefully damn close to the steering rod joint... I don't even want to think about that at the moment
Jwithing
Jwithing
STL
I was definitely off center and used a quarter inch bit... Looks like I started eating into the housing threads. At this point, I think I may need to leave the bolt in there and order some extra long taps to put in some new threads. Idk, at this point I feel like I'm just messing everything up out of frustration and exhaustion... I'm 35-40 hours in at this point....
