headlight adjustment
jojo750
south carolina
v6
since i lowered my truck, apparently my headlights are blinding people in the oncoming traffic. so i was wondering if there is an adjustment to lower the aim of the headlights?
2011 ram
i looked around the assembly and didnt see anything, but then again, it mightve been staring me in the face.
any help would be appreciated.
thanks
joey
HKkid
Missouri
Wait what? You lowered your truck and now you're blinding people? I don't see how that is possible. There are adjusment screws on the lights though.
jojo750
jojo750
south carolina
v6
same thing happened when i lowered my ssr.
seems since the rear was lowered more than the front, the headlights will actually point slightly higher. hard to explain.
if i aim at my garage door, my low beams are almost the same height as my high beams.
i just want to see if i can aim them a little lower.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I wouldn't say that! I would never look in the holes on the fender. Lol.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
yeah, crazy location for the aim!
quietpeen
2021 TRX
Hellcat
lol..id does go against thinking. but it makes sense since you did level it with the lower so how they were aimed is different now
Jmhm17
Massachusetts
5.7L HEMI
Yeah im going to bring this back from the dead.. I noticed there are 2 holes each one has an arrow.. I dont want to start cranking on one and not realize its the horizontal screw 20 turns later waiting to see a vertical change. anyone have an update on the newer Rams? I have a 2014 specifically
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
depends on your truck on the 13+
If you have the quad lights, use the hole that is furthest from the grill. The OEM projectors would use the hole closer to the grill
Jmhm17
Massachusetts
5.7L HEMI
oooooooohhh!!! that makes sense. it was really sunny out today and I noticed there was only a screw in the back one (I have quads), I figured the glare and how deep the hole was i needed to get a light in there to see the other screw, but according to you there isn't one. Perfect, thanks for clearing that up!! I feel dumb now haha
Pull Ya
Cedar Creek, Tx
I found out that on the 13's you have to go clockwise to lower the beam instead of counter clockwise.
jay
Andrew King
Butler county Pennsylvania
Is the adjustment for the whole housing or can you adjust the high beams separate? This is on the housings with a separate high beam bulb.
This EARLY Gen 4 Ram headlight is face down, the adjuster is pointing straight up in your Ram
2009 Dodge Ram
