Headlight Revolution vs Supernova V.4 (direct)
CoCaDoRi
North Dakota
I've been researching new LEDs for my '18 3500 (Laramie w/projector) replacement bulbs. I've spent a good deal of time on the HR website watching videos and comparing LEDs. Since HR does a ton of research tend to believe them .. Without question they recommend Supernova V.4 (Perfect fit) for the highbeam. Their price is $188 for a pair. If I go direct to the Supernova website it looks like can get the same bulbs for $99 a pair... soooo whats the deal?
Has anyone dealt with HR and are they just adding mark-up?
bfill_rebel
I’ve bought 3rd brake light and reverse led bulbs from HR. They are great quality and extremely bright. No bulb error messages. A little pricy but great quality
RedSRT4Me
Scottsdale, Az
2015 CC Sport
HR is a huge markup but for good reason. As you can see they do a lot of how-to's and charge what they think is market value.
I haven't used their products but from the videos I think they do a great job of comparing and contrasting options to choose from.
1500ram12
5.9L Cummins
I ran the v3's in my quad headlights and was very pleased. I'm currently running these
KATANA H7 LED Headlight Bulbs -... https://www.amazon.com/dp/B07J5CWZDL?ref=ppx_pop_mob_ap_share
In a set of projectors and am very pleased with them. They are the brightest led's I've run (I've tried a lot) and I'd say are brighter than a 35w hid kit.
2018 2500 6.4L
joshuaeb09
Medina County, TX
Interesting the Supernova v.4's from the direct website only have an amber 2 in 1 option which would irritate the hell out of me. They also look a bit different than the V.4's sets I have. The V.4's from HR I run in my high beam sockets are always amber and the perfect compliment for my Nightbreaker Laser d2s setup out here on dusty back roads or in the rain.
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
BRI Source has the Supernova Perfect Fit V4's for High Beam at 109.00. On back order till next Tuesday. Purchased the Supernova V.4 lows for 169.00
homeguy
Calgary AB
2013 Big Horn
I’ve got some 55w HIDs from HR. There warranty is excellent too. Great to deal with.
HM_SanDiego
San Diego
2018 Hydro/Laser Blue CC Sport
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
Hr is an awesome company to deal with. I just had my second failure on the v3s sadly but they sent me a set of v4s free of charge. They also upgraded to different switchbacks then what I bought from them almost 2 years ago. So they sent me a new set of them too without me even knowing or asking about it.
Their prices are high for sure. But they have been extremely helpful in getting everything working in my truck. Swapping canbus adaptors and overnighting them twice, as well as sending me a cell phone made video showing me how to get everything to fit inside the housings.
I haven't installed the new stuff yet but will this weekend hopefully.
Just went out to the garage to snap some pics of the new stuff. It really makes their v3 setup look like junk. These decoders alone are so much nicer. The old ones were these cheap plastic pieces.
Ram Night
Southwest, Michigan
QUOTE="CoCaDoRi, post: 2055286, member: 83716"]I've been researching new LEDs for my '18 3500 (Laramie w/projector) replacement bulbs. I've spent a good deal of time on the HR website watching videos and comparing LEDs. Since HR does a ton of research tend to believe them .. Without question they recommend Supernova V.4 (Perfect fit) for the highbeam. Their price is $188 for a pair. If I go direct to the Supernova website it looks like can get the same bulbs for $99 a pair... soooo whats the deal?
[/QUOTE]
They are great people to deal with, But you do not want to use Led's in your projectors. They will not work as good as the stock bulbs. Check into their HID low beam kit from GTR lighting. These are a true plug and play install. No relay harness or resistors to mess with. The Supernovas V4 LED's work great in the fog lights and high beams, but will not be as bright as a HID low beam kit.
Here is a good example of my GTR 35 watt bulbs, and Supernova LED's with the high beams. You can see how much brighter the DID bulbs are.
https://headlightrevolution.com/200...adlights-upgrade-low-beam-hid-conversion-kit/
1500ram12
5.9L Cummins
In the projectors, did you need to add decoders or error cancellers?
I didn't have to because I had changed the setting with alphaobd. But I you'd probably need some canbus adapters
2018 2500 6.4L
HM_SanDiego
San Diego
2018 2500 6.4L
Thanks for the quick response
I have LED kits in my cart ready to check out, but want to make sure I have everything I need before I take stuff apart.
I wish AlphaObd worked with Apple IOS......
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
They will send you everything you need. No need to worry there
If you go on the Alfa thread you can probably find someone near you to help you out too. But the decoders work fine. I just pulled mine out along with all the resistors after getting Alfa.
HM_SanDiego
San Diego
It is somewhat widely reported that the Katana’s are essentially the Supernova V4’s, at 1/4 - 1/3 the cost.
I can neither confirm or deny this, but I have read it in several reviews. Food for thought. If someone have additional information in this regard, please share.
C
CoCaDoRi
North Dakota
@Ram Night They are advertising twice the output as the stock bulbs.... you say the stock will be brighter?
At the end you see the comparison...
Guess I'm confused...
1500ram12
5.9L Cummins
Apparently he's working on getting approved by Apple. I was in the same boat as you with only having apple products. But I ordered a $50 Amazon Kindle fire 7 tablet to use with alphaobd
2018 2500 6.4L
1500ram12
5.9L Cummins
I've heard that also. That's why I bought a set. If I had a set of v4's or if anyone has some and can take pic's I'd pull mine out to compare
2018 2500 6.4L
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
2018 2500 6.4L
Posted one already. I can take some more angles if needed
chrisbh17
I have a set of katanas on the way if you want to wait for my pics instead of taking them out of your lights.
Sent from my Nexus 6P using Tapatalk
1500ram12
5.9L Cummins
If you can. Could you get a pic of the backside of the ballast and any distinguished markings
2018 2500 6.4L
Ghstrdr95
