Headlight Socket Replacement
htxdc
Moyock, NC
So currently my low beam headlight socket, pictured below, will not clip on to the headlight bulb.
I've looked on RockAuto.com and the replacement sockets do not match the picture above.
2012 RAM 1500 5.7L V8 Headlamp Socket | RockAuto
Am I missing something? Is there a replacement for this part? Any suggestions and help would be greatly appreciated. Thanks!
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
This part is causing trouble in my truck as well but it's the drl that goes off while plugged in. I'm going to just take the clip out of the equation and solder the wires together.
Sent from my XT1635-01 using Tapatalk
jwheeler
Washington
Try your local dealer. They probably have them in stock. It is a really common problem.
htxdc
htxdc
Moyock, NC
I might attempt that too if you don't have any issues after soldering the wires together.
