Headlight washer fuse.....
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
So I noticed that there was a empty headlight washer fuse space in my fuse box. My question would be is how difficult would it be to wire such a set up if say I had the appropriate fixings/hardware? Just curious. It can't be rocket science......
NJMOPAR
Older and faster
ELizabeth, NJ
Might be there for another model & FCA uses the same box across different brands.
I could see a Chrysler 300 with headlight washers, haven't heard of it on a Ram but who knows?
Rebelrouser
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
So the reason I ask is because- I know alot of you's are going to ask "Why" but....- I have all I need to install washers for my headlamps. I found a decent set of almost flush mount washers that I think will work and look almost factory when done. My question is" How do I go about hooking up a second switch for an auxiliary pump that I am incorporating into the washer jug? Also I forgot to mention the squirter's are heated. How would I go about wiring them to say my heated mirror/seats switch as well. I know there is a way to get this done all I need is a little coaching to actually installing it and making it functional. Thanks ....
gville35
