Headlight
greg.hunt.18041
Can anyone tell me how to get to my head light to change the bulb on my 2012 1500. I am kinda mechanicly inclined but can't seem to find this one out.
Thanks
Sent from my SAMSUNG-SM-G920A using Tapatalk
1500ram12
5.9L Cummins
If you do a quick search you'll find multiple threads on how to remove headlights.
Basically the plastic air dam thing on top of the grill and rad support needs to be popped off (I wouldn't worry about putting it back on) you'll see 4 10 mm bolts holding the top of the grill on. Next grab the lower corners of the grill and with a swift pull (one side at a time) pop the lower corners out. There are 2 10mm bolts holding the lights in. In the fender well facing the front of the truck you'll find a flap. Open it and reach in. You'll find a plastic clip that needs to be pushed up. Once you push it up you'll be able to pull the light out.
Sent from my XT1585 using Tapatalk
G
greg.hunt.18041
Thanks, I looked at lol you tube. & found a video on that same procedure.
