Headlights always stay on when in auto mode
sstumpf
Central IL
My headlights are always staying on in auto mode, even when it is sunny out. They never shut off. Any ideas on what this could be? Almost would have to be the light sensor in the middle of the dash. But I cant seem to find a part number for a replacement.
csuder99
Questions:
Is it just the headlights or are the tail lights/running lights on as well ?
Is this a new problem ?
If bought used, is this a Canada market vehicle ?
sstumpf
sstumpf
Central IL
It is a truck from Canada. So the DRL's are always on, which is fine. That is just the turn signals. But when headlights are in auto, the headlights and taillights are always on, as well as the DRL turn signals. When I turn the headlights to the off position, only the DRL turn signals come on. It has been doing this for months. But would like to get it fixed so I can put in some low beam hid's. And there is nothing on the dash covering the sensor.
68230114AB Sun Sensor
This is the part number dual sun sensor used in trucks with ATC. Trucks with MTC only have the single sun sensor for headlight control, but the dual one works also.
sstumpf
sstumpf
Central IL
Great, thanks. Mine has ATC. It's a lot cheaper than I thought. Only $25. So I'll go ahead and replace it and hope that fixes it.
sstumpf
sstumpf
Central IL
Well I installed the new sensor and it's still doing the same thing. Oh well, it was worth a try. But not sure what to do now. Any other ideas? I'd hate to have to take it to the dealer.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
Try taking your headlight switch apart and inspect that. It's easy and free.
sstumpf
sstumpf
Central IL
Well i gave that a shot, still doing same thing. Not sure what else to do other than take it to dealer. Maybe it's a software thing.
Loudram
Navy Badge
South Jersey
Hemi 6.4L
Sorry man, let's us know what they find.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You don't by chance have an aftermarket radio installed do you?
sstumpf
sstumpf
Central IL
Nope, factory 8.4"
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Nope, factory 8.4"
Ok, I've seen this happen with a T-Style radio. They aren't DRLs are they?
sstumpf
sstumpf
Central IL
Not DRL's, the led turn signals are the drl and that is working fine. For now, I have just been manually turning the headlights on and off.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Did you set them that way with AlfaOBD?
Raymond1050
arizona
eco diesel 3.0
If you have the U connect radio there is in the settings mode a way to change the time the lights stay on. Check it.
sstumpf
sstumpf
Central IL
I'll look into that. Thanks.
