Headlights mounts
2011ramster
Southeast, PA
5.7L hemi
So let me start off by saying I probably have taken off my headlights over a hundred times lol. Now the holes you would use to mount them are worn out and the screws just turn and don’t tighten down. What would be a way I could fix that? Put a threaded insert? Rivet nut?
OC455
Central NY
Top or bottom mounts?
2011ramster
2011ramster
Southeast, PA
5.7L hemi
Both honestly. It’s a 2011 so it just screws in to the plastic and the holes are pretty much worn out so the screw doesn’t tighten
2011ramster
2011ramster
Southeast, PA
5.7L hemi
Cordless drill for what? If your referring to the reason why the hole is worn out. Like I said I’ve probably taken my headlights off 100 times so yes they are gonna get worn out since it’s plastic
