heat/ac issue
2515x3jj
Newport, Pa
Hello to all and thks for looking at my post. My issue is the ac/heat blows out the defrost on acceleration and when I let off it goes back to the selected position. I can hear a door shut when letting off. Is there anyone who experienced this issue. And what was your fix. I'm putting a heater core in this weekend and this would be the time to check for the problem. Thankyou
Mop
You'll find other threads on this. It's a vacuum leak. Look at the thin, black hard plastic tubing on the firewall, passenger side. The line probably has a crack, or the check valve is bad.
My line was cracked, and I cut it off, added 3mm rubber tubing onto the existing line. Simple, cheap fix.
