Heated seat control module question
Cdndewey
Vancouver Island BC
I need some help. I bought a 2015 Ram 1500 SLT, and the owner changed the seats and there's no heated seat control module. He couldn't remember what the seats came from, but a buddy of mine THINKs they're from a Laramie.
Was wondering if all control modules are the same and if I buy one for a 2015 Ram 1500 from Mopar Parts Giant, would it work?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
@Mpgrimm2 might be able to help. He makes custom harnesses for mods like this and likely knows exactly what's needed to get it working (if it's OEM).
C
Cdndewey
Vancouver Island BC
It's not really a mod, as the truck has the controls on the dash for it. Unfortunately the previous owner can't enlighten me on where the original module went.
RamDiver
Marlborough, Ontario Canada
2021 DS
When SKB mentioned Mpgrimm2 made harnesses for similar mods, he was suggesting that Mpgrimm2 has a very detailed understanding of the operation of this system and could explain the requirements better than most.
And he's usually very generous with sharing that knowledge. :cool:
emjohn4
All of the HSMs are generally the same in the 2013-2019 trucks; but vary due to options. There are different HSMs available on the below options:
Heated Front Seats
Heated Front & Back Seats
Heated Front & Cooled Front Seats
Heated Front & Cooled Front Seats and Heated Back seats
And...
Add the option of heated steering wheel to each of those, and you've got at least 8 HSMs to choose from.
5th Gen HSMs are different than 2013-2019 HSMs, which I believe are different than 2009-2012 HSMs.
You can get 'any' HSM you need from a RAM that has the options and year range you need and it should work.
RamDiver
2021 DS
So the same and unique, all at the same time. :cool:
Thanks for the clarification.
If anyone has the Mopar part numbers for all those same/unique modules, we would all be more knowledgeable.
The HSM in this link seems to cover several of the variants for 2013-2018 Ram 1500.
I wonder if we can find a Canadian outlet for the OP.
C
Cdndewey
Vancouver Island BC
A Cdn outlet would be awesome.
emjohn4
#5 in the attached. There are 10 combos - not sure what the 'extra' 2 are that I couldn't idntify off the cuff; but there they are in the attached.
  • 2012 - Body Module Listings PNs.pdf
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
There's a lot to this beginning with whether or not you actually have 13-18 compatible seats, factory installed wiring for seats (very unlikely with an SLT), and a compatible 8.4 radio/HVAC system to start (also unlikely with an SLT). All of which can be remedied.
Send me a message/conversion if you'd like to get things moving with what you need vs what you have.
Also take a look at ...
Driver Seat Connectors for Reference - Post 2025.
PS: just because the dash switches are there doesn't mean they came with the truck from the factory and will work. Would need a typed out VIN (All CAPS) to pull your build sheet and check.
C
Cdndewey
Vancouver Island BC
Where do I get a build sheet?
C
Cdndewey
Vancouver Island BC
According to the build sheet it has the Heated Seats and Wheel Group...now to find a control module. The missus really loves the hrated seat...had them on the Jeep Grand Cherokee.
Mpgrimm2
SC
5.7L
Reach out to forum vendor @AllMoparParts with your VIN and they (Benny) can identify the correct PN module for your truck.
There's also some mentions of it in Roman217's post 2967 here. (Not sure if it's the same for your heated only seat set.)
Mpgrimm2
SC
5.7L
Do you have a contact for AllMoparParts?
All Mopar Parts << click the link to get to their vendor section and Click their Forum avatar to message/start a conversation with them though the forum for possible discounts & get ETA/verify availability.
RamDiver
2021 DS
I got this part number from a dealer near me. Do you know if 68217268AFT is the correct part #.
If you search that p/n online, it shows endless results as being the correct module for the drivers heated/cooled seat and steering wheel for 2011-2024.
Live on the edge a little. :cool:
