maitai11
Hey Fellas,
A few questions; I have a 2014 Ram 1500 5.7L SLT. I'm going for a major upgrade with the premium cluster, tricked-out steering wheel, and heated seats.
1. Heated Seats: Already installed (except for wiring) under custom made LeatherSeats.com replacement upholstery. I need to know:
a. Which wire to tap into so that the controls are on the ignition circuit
b. Can I use the five-button console below the HVAC system to control both seats, instead of drilling into the seats and putting in the cheap switches?
c. Should I run separate circuits for each seat?
d. Or, am I missing the (possible) fact that I can use some of the wiring and tap into it underneath the seats?
2. Heated Steering Wheel with audio control: I have the steering wheel and required clockspring assembly.
a. What else in the way of electronics or module would I need to make this work? I am NOT trying to use the buttons on the touchscreen or anything. It will be one of the five hard buttons below the HVAC system.
b. Again, can the hard buttons below the HVAC system be used for the heated wheel?
3. I'll also be adding an aftermarket backup camera and the premium cluster. I would like to get this all done while I have the dash torn down and the extra accessibility to make these changes.
4. At current, the only buttons in use on the hard buttons are traction control and tow mode.
Thanks in advance; this will be a fun - but extensive project. You guys are golden with your knowledge.
Best,
Maitai
Best,
Maitai
