If the rear window defog switch doesn't light up on your remote start but you heated seats and wheel do there is something glitching somewhere. They are all supposed to come on together on remote start if it's 40° or less. I have had mine not come on every once in a while for some reason but it's rare. You can also turn them on whenever you want by just pushing the button once your in the truck but it's nice to have the mirrors defrosted before you get in the truck. I'm pretty sure the mirror defrost button will time out after a while and need to be pressed again "at least mine does" so don't wait to long after you start the truck to check. I usually remote start mine and look through the window to make sure everything comes on as it should.
Sent from my SM-G981U1 using Tapatalk
OK, help me out here.
Info: 1) I do not have remote start.
2) I do not have a rear window defroster, defogger.
3) I do have a rear defrost switch located right underneath the front defrost switch.
If I manually push the rear defroster switch it will light up.
This morning the OAT was 6* F ( approximately -14* celsius )
When I started the truck, briefly after starting the heated steering wheel and heated driver side seat lights illuminated ( without manual input ) and heat began to be felt in both seat and steering wheel. The rear widow defrost light DID NOT illuminate. After waiting a minute or so the outside mirrors did not feel warm.
I then manually activated the rear window defrost switch. It did light up. After a couple of minutes the outside mirrors still did not feel warm. I activated the front defrost button ( it did light up ) and the outside mirrors still did not feel warm. I do have he wavy lines on my mirrors and my Laramie trim level should have heated outside mirrors. Build sheet search by VIN confirms outside heated mirrors.
Thats about as precise as I can be in describing what I am experiencing.
In all vehicles I have owned with heated mirrors I could feel the warmth on the mirror surface when the heat is activated. As usual, dealer told me mirrors are functioning when I asked about it and truck still had warranty. Warranty does not apply now.
Would someone who has heated mirrors let me know if their rear window defrost switch lights up with a manual start on a cold day? Also, if you place your hand on the mirror glass does it feel warm or even hot to touch?
Thanks folks.
