height issues
tallen4392
western ma.
hi My 2012 1500 I bought used it came with bilstein on all 4 corners the front set at 2.8 the more I drive it I notice the front sides are not the same height the right frt is 1 inch lower than the left .I was looking around under it and see nothing wrong both clips are still in the 5th slot drives fine the alignment shop said they saw nothing wrong any ideas ..
buddy guy
alberta
if it indeed is 1 inch lower on one side, one possibility is there's a washer with the Bilsteins that quite often does not get installed in the right spot (under the cap, not on top is correct) and the rod of the shock can start pushing through the cap. i don't think you can see if its installed correctly or not without lifting that cover over the top of the shock. (maybe through the engine compartment?) someone has taken pictures that show the right and wrong install so there must be a way to see it from underneath.
FF1899
Syracuse NY
That wont effect the ride height that greatly the spring is still in the same position regardless. However I would double check that just to be safe. As for the ride height issue I would look to confirm that the springs are seated in their perches correctly both top and bottom. If they are chances are it is spring sag
quietpeen
2021 TRX
Hellcat
also make sure the spring perches are installed the correct direction.
buddy guy
alberta
they can be put in upside down, believe it or not. you want them facing so they cup the coil. there's a kind of tube part of the perch that should be facing up and will be inside the coil. if you see that extending below the cup the coil sits on, its been put in upside down.
T
tallen4392
western ma.
They are on the right way thanks.. I will probley try that 1/2 spacer thanks for that info ..I took the truck to the alignment shop he says it is within specs but I don't think it should be off that much. My son has a newer truck and both sides are spot on maybe I am worried about nothing.
