Hella 700ff
usmc1217
Fremont, CA
Well my hella 700ff series lights finally came in. So far I've prepped all the wiring, replaced the stock ****** connectors with some all weather ones and a new 30 amp toggle switch bc the one it came with looks kinda outdated IMO. Anyways. 2 questions
1: what would be the best way to run the yellow and green wire to the toggle switch inside the vehicle WITHOUT drilling a hole in the fire wall?
2: since I have four lights. Can I connect 2 ground wires together to create a single ground wire? And then ground that.
gofish101
2018 Outdoorsman CC
Right beside the main group that go into the truck is a little rubber nib/nipple whatever you would call it. I used that to run wiring for 2 sets of lights.
Musclemckeester
Houston, TX
n/a
n/a
You can splice the lights together as much as you want. I have 4 HID'd Hella 700s all run to 1 switch and 2 grounds.
WhiteExpress
Midland, TX
You can splice together all you want. Just remember that you'll be increasing the load on that wire.
I would run all the ground together, and ground where the light bar mounts.
I would run each pair of lights on a pair of relays mounted under the hood.
There is a 1.5" x 4" plastic plug in the firewall for where the clutch assembly would go, this is a great place to run wires through. Can be removed to drill and install a grommet, then just pass through your wires.
kkreit01
Olathe, KS
I used the rubber nipple as well. Just snip it off, and run your wires through. Tape or silicone around them when finished.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Take pictures when you're finished.
*edit*
****. I just realized I blew past my 2k. damnit
Sparkyy
Northern New Jersey
v6
I put an all weather fuse under my hood and tied that to my battery for a direct connection and ran the relayed cables through a rubber boot high up and on the drivers side to my cab. Zero drilling, just followed the existing cables in but had to remove the shin guard to get access to everything.
Put the switch and relay in the cab and I have zero wires showing.
usmc1217
usmc1217
Fremont, CA
i like the idea of no drilling, i do recall seeing that 1.5" by 4" plastic piece. perhaps tomorrow ill get around to it..today i had to remove the headlights and reinforce four ballasts for my headlights that were coming loos. tomorrow ill spray the side steps and put the lights in first thing tomorrow morning!! oh yes and ill definitely post some pics.
thanks for all the helpful tips/advise gents!
AC54ME
Plano, TX
2013 Dodge Ram 1500 Lone Star
Great to see so many helpful assists by members.
Semper Fi
(1959 - 1969 MOS 7522)
usmc1217
usmc1217
Fremont, CA
Thank you for your service Sir
Semper Fi
(2009-2013 mos-0331)
Fpye
