Help can’t remove lower control arm bolts
acolic
Hamilton
Hi
I’m in the process of replacing the lower control arms on a 2006 Ram 1500.
I have removed the nuts but I can’t seem to be able the remove the bushing bolts.
I have tried to hammer them out and I have tried an impact.
These bolts should just slide out?
smithwessn
Those bolts are known for rusting in the sleeve of the bushing. You'll probably need some combination of penetrating oil, heat, and impact.
bigdodge
Just cut them and buy new bolts. So much easier.
Karlsweg
SW Florida
PB Blaster and an impact gun tightening and loosening. And keep spraying Blaster and it will come out.took me about an hour a bolt but I had to recharge my electric impact several times during. New bolts with anti seize when putting it back together!
A
acolic
Hamilton
Hi
Thanks for the advice.
I cut the lower strut assembly bolt off and now I am working on the lower control arm bolts.
It always makes me laugh how easy things seem in the YouTube videos.
