Help can't decide
DirtDog
Hemi5.7
I have a 2014 reg cab with a M/G deluxe 2/4 drop. I can't decide if I should go with 22inch or 24 in wheels. With 22's I can run the stock size RT tires which are 285/45/22 32.1 inches high. This would lower the truck another half inch and keep the tires from sticking out any further. The wheels for these would have a +15 offset and be 9 inches wide. The 24's would have the same specs and the tire I choose is 285/45/24 which is 33inches high same as stock. I am trying to visually get the truck to look lower. What do you guys think?
TylerB
FL
I think you just answered your own question.
gunner1374
In the 405!!!
HEMI 5.7
+1^^^ I personally like the bigger rim look, but I would seriously consider the weight of each and go lighter. Either way, I am sure it will look good.
BlkRamRt
SoCal
HEMI 5.7
If I had to choose i'd go with the 22's
audio1der
Airdrie, Alberta
The 24" rim/tire combo likely weighs more as mentioned above; it will hurt your MPG, braking and acceleration but look BADASS. It may also ride more harshly- not sure how your roads are.
14hemiexpress
6.4l
The only advantage of the 24 is keeping a stock height tire witch will keep your speedometer accurate, if you have a tuner or don't care about the speedometer being off then the 22 I think will give you more of the look your looking for, and they will be lighter.
joshhhh
