HELP!!!! Need some Info...EVIC Upgrade
moparpeetie
south central PA
so I did the EVIC cluster upgrade to my 2012 Express... steering wheel controls installed, even put the module on the frame rail(LF wheelwell)off a 2010. STILL doesn't read TMPS. EVIC shows 0 psi all 4 tires. Flash???
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
How long have you drove it around?
JRG18
Northern VA
6.7 CTD
Should match the parts to your model year or newer instead of using an older year. Other threads about the cluster upgrade in the 13-16 trucks have what sounds like the same TPMS problem.
moparpeetie
moparpeetie
south central PA
I used a EVIC out of 2012 & module out of 2010 which, in the parts catalog is the same part #... It may be a defective module, I did get it out of the yard... I'll get another module(new) & go from there. Thanks!!
JRG18
Northern VA
6.7 CTD
Yeah, sounds like a safe bet to start there. Good luck.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I have one of the Homelink modules for 2012 and below if your interested.
