HELP - SOS Radio Blank Screen
VdubBry
Hey all,
I was starting to do some pre-wire for the system I plan to install on my (8.4A - No Alpine).
I was tapping the speaker level wires so I could add a clean sweep and realized I should disconnect the battery to be safe.
So I did, tapped the lines etc, re-connected and no screen at all. There has to be a fuse or something I messed up, the stereo was working just fine minutes before. I found no fuse for Radio in the manual.
I tried jiggling all the wires in to the harness that plugs in to the radio, I disconnected where I tapped the speaker levels, triple checked that what I did tap was in fact the speaker wires. Not sure where else to go other than the dealer.
What could have happened?
VdubBry
VdubBry
Update - Resoloved. I found that the radio has a fuse separate of the entire system. It's a 20A fuse you have to follow the wire running from the battery and it's in a protective rubber casing.
Thanks
PX8
2013 Express Crew Cab
Awesome! Good save.
Steve58
